Forum Post: RE: Performace degradation between / /Power8
  • Thread starter Thread starter Rob Fitzpatrick
Rob Fitzpatrick
I'd also run this batch client with -yx. At the end of the batch run, look at proc.mon to see which procedures register the most execution time. If there is an outlying value that could lead you to a code-related issue like the one Paul described with the repeated chmods. Also, double-check the other client startup parameters and see if something obvious is missing. Where does the batch client run? Is it self-service or shared-memory? Where does the code reside relative to the client? Is it r-code or procedure libraries? Or compile on-the-fly? Is the client using -q? Where do the client's temp files reside (-T), and what is their size and I/O during execution? How many databases does the client connect to? It would be helpful to know all of the client and broker startup parameters, including those in parameter files.
