P
Peter Judge
Thomas Mercer-Hursh The other is finding the project. In the old days the PSDN source code library had a fair amount of stuff in it, but it was impossible to find unless someone provided a link. You *might* find it if someone told you about it and gave the name. If you were just poking around wondering if there was something to address a particular problem, then it was a long shot whether you would find anything before you gave up. This is what the Code Share area here on Communities is intended to be - a central place for links to various others' code. The only way that Communities can 'host' code (and I use that word lightly) is via uploaded archives. Jean posted a doc at https://community.progress.com/code_share_group/m/documents/773.aspx with how you can do this. -- peter
