F
Frank Meulblok
"in this case all the temp-tables are being statically defined" Does that also apply to the temp-table parameter definitions ? Meaning: You're not using table-handle or dataset-handle parameters ? Otherwise, may want to read this article as well: knowledgebase.progress.com/.../P112397 on implicitly created temp-tables. Note, the article on the client logging Julian linked to should catch those implicit temp-tables as well.
