Sven Cuypers
Hi, I have tested this over here and I'm able to connect to the on-premise Oracle DB. Also, when clicking on the tab 'SQL Testing', I can successfully retrieve the schema information. I have tested this against an Oracle 12 db running on VM. I installed the Cloud Connector, entered my Progress ID credentials and copied the Connector-ID into my D2C datasource on the dashboard. I also entered : Hostname Portnumber SID User Password Can you check if you have completed the same steps and let me know to which Oracle version you're connecting as well as on which platform it is installed. Thanks, Sven
