P
Prasanna Anireddy
Hi Mike, The CONNECT procedure only takes two input parameters for userId and Password. DEFINE INPUT PARAMETER p_cUserID AS CHARACTER INITIAL "" NO-UNDO. DEFINE INPUT PARAMETER p_cUserPwd AS CHARACTER INITIAL "" NO-UNDO. Please refer to “Performing Secure CRUD Operations” section in the User Guide of “OpenAccess for OpenEdge Application Server” for more details. Sample implementation of the connect procedure is available in below sample oasamples/oe11/security_cfg/si/oa/connect.p Also what version of OpenEdge are you working with. The Secure connections are currently not supported with OE 10.2B. Thanks Prasanna From: Akioma [mailto:bounce-Akioma@community.progress.com] Sent: 12 March 2015 PM 09:36 To: TU.DD.Connect@community.progress.com Subject: [Technical Users - DataDirect Connect] OpenAccess for OpenEdge signature of connect procedure OpenAccess for OpenEdge signature of connect procedure Thread created by Akioma Hi all, when connecting from OpenAccess to the OE AppServer a connect procedure is called. Can anybody tell me the parameters this procedure is expected to provide? I tried it with the same signature as a standard AppServer connect procedure (INPUT CHAR user, INPUT CHAR PW, INPUT CHAR pcOther) but I get an Error in the AppServer log: AS -- Mismatched number of parameters passed to routine server/openAccessConnect.p. (3234) AS -- ** ABL Debug-Alert Stack Trace ** AS -- -- server/openAccessConnect.p at line 0 (c:\Users\IDa_wf\git\dev\opt\crm\tty\server\openAccessConnect.p) Thanks, Mike Stop receiving emails on this subject. Flag this post as spam/abuse.
