Forum Post: RE: Open Edge 10.2A and creating a silent install
  • Thread starter Thread starter foozie000
F
foozie000
Thanks kyeddula. I did find the steps you indicated in another post and it didn't work but I will try try again. I am only using netinstall (as this is the preferred method) so I can't tell you if this works another way. Since this is a silent install I just run a cmd file and it opens the command prompt, then loads .NET if it isn't there. Next it is supposed to run the Progress Software silently but it seems to start and end right away. I'll keep you posted on my progress
