Forum Post: RE: OE Management: How to Delete Messengers?
  • Thread starter Thread starter Matt Baker
Matt Baker
Don't monkey with fathom.xml. You might not get the cross references (resource monitors and such). If you reallllyyy want to get rid of them... Take out this section from AdminServerPlugins.properties if it is present. # # WebSpeed Messenger PlugIn # [Plugin.WSMessenger] dependency=Plugin.System,Plugin.WebSpeed license=4980736 classname=com.progress.ubroker.tools.MSGuiPlugin pluginargs=Messengers Modify $OEM/web/messengers/msngrinsthome.jsp Add the following line into the html form: %= cfgbean.getStandardButtons(4) % Save and restart adminserver (edits may not show up if you've touched this page since they are cached if you don't restart). Navigate to the resource page for the messenger and press delete.
