Thomas Mercer-Hursh
Why a new thread on the same topic. Lacking a response which solves the problem here, I recommend opening a support case as suggested on the original thread. The other thing you could try is to do the select with a starting key supplied that will put you higher in the stack. If that gets you the same number of records, it will be very clear that the problem is a property of the connection.
