Forum Post: RE: Not possible to send Push messages with HTTP Post triggers on Private Cloud
  • Thread starter Thread starter ajsharma
ajsharma
Hi Bal, Yes you need to register the device into push database then only it will deliver the message. Normally this registration is automatic process. I would suggest you to check if your device is registered in Push Notification database. if not then please uninstall & install the app on device again & run the app so the device get registered. Then you try to send the Push Notification I hope it should work without any issue. Regards Ajay
