Forum Post: RE: Mobile Project, uses TTY, Is there another way to....?
  • Thread starter Thread starter Swathi Yellavaram
Swathi Yellavaram
It is possible to change runtime of Appserver project. As files which get published to appserver are not UI files and also to compile files with tty runtime, default runtime is TTY for OpenEdge Appserver project. If you plan to work on windows only then you can modify the runtime from Project properties. Deselect Use TTY for runtime option in 'Progress OpenEdge' project properties page. Thanks, Swathi.
