P
Peter van Dam
So Andrew, you are basically putting everything belonging to the module, OE or not, in an OE project. You are saying you can select one (or more?) directory within such an OE project that is actually treated as an ABL source directory. That must be something I have missed so far. How do you do that? Can you do that for more than one directory? How do you determine where the objects of each directory go? Until now I have only worked with build destinations (objects and static files) but that is an all-or-nothing approach that applies toe the entire project.
