Manooj Murali
Hi- There are similar posts currently active in the forum & it looks like its for the same issue. community.progress.com/.../69280.aspx community.progress.com/.../70002.aspx PD4ML recommends running the following command against your font directory (refer pd4ml.com/.../ttf-embedding-t42.html ) java -jar pd4ml.jar -configure.fonts /path/to/my/fonts/ Once, this is run, a property file is generated & you need to rename it to pd4fonts.properties and put it in the font directory. (Note: In case of windows, this may not be required). Can you please confirm if these steps were executed on your environment? If you see still see the problem after having executed these steps, could you please confirm if directly generating the pdf (refer http://pd4ml.com/examples.htm ) by following the PD4ML command line tools works for you? Note: Please execute the command line test using the same pd4ml jar you are using in rollbase. Also, I noticed that you have a pd4ml_demo.jar? Is that a licensed version, if yes, can you please confirm what is the pd4ml version you are using? -Thanks
