andrew.may
You can configure a project’s AVM (or the Workspace’s default AVM) to use a specified .ini file by specifying “-ininame MyIniFile.ini” on the AVM startup parameters. Workspace shared AVM settings are here: Window Preferences Progress OpenEdge Configure Shared AVM Preferences Project-specific AVM settings are here: Project Properties Progress OpenEdge Startup parameters For run configurations, if the run is set to use the project/shared AVM then no config is required. If using a run-specific AVM then you can configure it here Run Run Configurations ..select your run config… ”Startup” tab Ini File: From: PeterWokke [mailto:bounce-PeterWokke@community.progress.com] Sent: 01 September 2014 12:49 To: TU.Mobile@community.progress.com Subject: RE: [Technical Users - Mobile] How to set specific fonts for a workspace. RE: How to set specific fonts for a workspace. Reply by PeterWokke Hi Keertthy, I have found this part in the properties. But I have to set the progress font settings so I can add the font specs from font 8 and larger so I can compile my source without error 4499. font8=tahoma, size=14 font9=tahoma, size=10 Normally this is in the ini file. Could set it in the progress.ini but I would like to specify it differently for each workspace. And I am not sure if the progress.ini is used in the PSDOE. Hope for your replay. Regards Peter Stop receiving emails on this subject. Flag this post as spam/abuse. Business Computer Projects Ltd is a limited company registered in England and Wales. Registered number: 1813992. Registered office: BCP House, 151 Charles Street, Stockport, Cheshire SK1 3JY. Tel: +44 (0)161 355-3000. Fax: +44 (0)161 355-3001 Web: http://www.bcpsoftware.com Disclaimer: This message, and any associated attachment is confidential. If you have received it in error, please delete it from your system, do not use or disclose the information in any way, and notify either the sender or Postmaster@BCPSoftware.com immediately. The contents of this message may contain personal views which are not necessarily the views of Business Computer Projects Ltd., unless specifically stated. Whilst every effort has been made to ensure that emails and their attachments are virus free, it is the responsibility of the recipient(s) to verify the integrity of such emails.
