B
bronco
well, on point 1) I think it preferable from a performance point of view to re-use instead of reconnect. Parsing the WSDL over and over again is quite time consuming (apart from the problem you mention, did you contact techsupport?). The second point is clearly a problem with the other side since the rules (about datetime in XML, xsd:dateTime) are quite clear. IOW, the other side is misbehaving instead OpenEdge having a problem (at least that's my opinion).
