Forum Post: RE: Help with the following SF Insert through D2C
  • Thread starter Thread starter markb
markb
One other thing about Map Options. If the value of Map Options is changed on an existing data source, the map for the data source must be rebuilt. To rebuild the map change the value of the Create Mapping option to Force New and then select save and test. Then change the value of Create Mapping back to Not Exist and save the data source again. Setting Create Mapping back to Force New will prevent the map from being rebuilt on every connection request. If the map for the updated data source is not rebuilt you will get the following error the next time a connection is made. [d2c][JDBC Cloud driver][Salesforce]The configuration options used to open the database do not match the options used to create the database. The Data Source Manager should rebuild the map automatically when the Map Options are changed, but currently that does not happen
