C
CMI
Hey. Well Done. I've been trying to use the zLib library on-and-off for years, with no real luck apart from being able to compress memptr using the DEFALTE algorithm of zLib. I'm reading a compress GZIP data from a socket as part of a HTTP/web client. Why would you think that the compress memprt would fail when calling the uncompress() method with the following error 'Error on data uncompression. However if I write the compressed memptr to a file then call the uncompressFile() method it works. Is there some extra headers in the GZIP data which is stripped as part of the gzread procedure in the zlib library???
