Forum Post: RE: GUID/sequence
  • Thread starter Thread starter Stefan Drissen
Stefan Drissen
beginetienne Adding "if true then." slows down on my version of OE much more than 2 ms for 1M iterations. Increment a variable, or casting an integer to string is just as slow as guid(). i = i + 1 is "slow", in comparison to an iteration with no code. I'd rather have a faster substring() function than guid(). This sounds a lot like another conversation on the PEG (or here don't remember) about class instantiation in ABL vs .NET. E- I'm using prowin.exe on 11.4 x64 on Vista x64 on a five year old i7-920. For one million iterations: description ms empty loop 221 if true then . 388 today 847 time 747 string( ii ) 737 string( ii, " 9" ) 1788 substring( "", ii, 1 ) 588 it = it + 1 653 guid 50000 This is not slower - it is crawling. But again - just an observation. Right... so I pulled out 11.2.1 32-bit - 1 million guids in 472 ms.... Is the 11.2.1 guid generator broken and functionally fixed at the expense of performance in 11.4 x64?
