Michael Jacobs
Base-64 encoding is case-sensitive and having two values that vary only by case is perfectly acceptable. So using caps() will induce collisions with other base-64 encoded UUID values and not allow you to recover the initial raw value. So this is not a valid workaround. for example: the value 2000 encodes to "MjAwMAo=" : if you uppercase and decode "MJAWMAO=" you get an invalid value ( 0?0 ).
