C
csands
To get that message, the driver thinks it is running against a hive 1 server. Is this what you intend to do? If so, can you tell me the vendor and version of the hive server i.e. Apache 0.12, Cloudera 0.12.05 Hive2 is a more stable, multi user server. You should consider using it. Also as of Hive 1.0, the hive server 1 is no longer supported by Apache. If it is a hiver 2 server. Change the WireProtocolVersion connect setting to 2 (hive server 2) And see if that fixes your problem. From: Phil [mailto:bounce-pprudich@community.progress.com] Sent: Tuesday, March 24, 2015 5:07 PM To: TU.DD.Connect@community.progress.com Subject: RE: [Technical Users - DataDirect Connect] Error when connecting to HiveServer using DataDirect ODBC driver RE: Error when connecting to HiveServer using DataDirect ODBC driver Reply by Phil That error comes from the server itself. Was there more to the message? Some versions of the server appear to provide more followup information which may be of use. Alternatively, you may need to consult your server log files if you haven't done so already to see if more information may be available there. Hope this helps, Phil Stop receiving emails on this subject. Flag this post as spam/abuse.
