Sasha Kraljevic
Hi Marilyn, You are probably missing r-code for that sdo - it didn't compile properly, or AppBuilder cannot find it in the PROPATH. Please check the following KBase: 000031960 - Error: " sdo-file-name SmartDataObject has no AppServer partition defined and is running locally without proper database connection(s)" running a SmartObjects application If that doesn't help, then check if your sdo instance erroneously has some AppServer service set by clicking onto the little minus sign in the sdo icon also known as 'ventilator'. If there is something set there, then set it to 'none'.
