Davy Vanhoudt
Hi, Can you let us know which Cloud Datasource you are using (Progress OE On Premise,...) ? Can you get us an ODBC trace of the error? 1. Select: Start Settings Control Panel Administrative Tools Data Sources (ODBC). 2. Select: the 'Tracing' tab from from the 'ODBC Data Source Administrator' dialog. 3. Enter: The trace log file or accept the default if any. 4) Click on 'Start Tracing Now'. 5) Click 'OK' Restart the application and reproduce the error. These steps start the trace and log entries in the file you specified. After you finish the query, come back to Tracing again and click on 'Stop Tracing Now'. NOTE: Make sure you delete previous log file each time you run a new query otherwise the log file is appended and a huge file can be created. Thanks, Davy
