Gary Clink
Hi Valeriy, Sven is correct in what he says about the current data-soruces and also the ones on the road map, but one thing you might want to consider is to take a look at OpenAccess. Depending on the opportunity, the technology, etc it may be possible to add additional data-sources for specific technologies or applications to Easyl (this isn't a quick process though as it requires certification and agreement by Product Management, etc but it's certainly possible). As an example, I am working with a UK based OpenEdge Application Partner at the moment to see if there's an opportunity to add their application as a specific data-source in Easyl. This would be achieved using OpenAccess for OpenEdge - something that can be "easyly" (get it
) replicated not only for OpenEdge customers but also in theory any data-source or technology. It might be worth having a chat with your account manager to discuss your requirements, but to be clear if there's a strong enough business case then anything is possible.... Hope that helps. Gary
