spanyala
Hi Rajinder, Rollbase provides a path to create a new object using Data Direct Cloud (D2C) service. To create D2C object in Rollbase user should have valid D2C credentials and a valid connection name. Step 1: Creating a datasource connection in D2C Step 2: Creating a New Object in Rollbase using Data Direct Cloud service Step 1: Creating a datasource connection in D2C 1) Login to Data Direct Cloud ( www.datadirectcloud.com ) with valid credentials. Progress pacific console page will be displayed. 2) Click on “Connect with Data Direct Cloud”. Data Direct Cloud dashboard page will be displayed. 3) Click on Data Sources tab. Available data stores list will be displayed. 4) Click on Progress OpenEdge Icon. “Create Progress OpenEdge Data Source” dialog will be displayed. 5) Enter your desired connection name (Ex: OEConnection) and enter valid OpenEdge db account details in “Create Data Source” dialog 6) Now click on Save and Test. Make sure that connection is successful. Now D2C OpenEdge connection is ready. Step 2: Creating a New Object in Rollbase using Data Direct Cloud service: 1) Login to Rollbase ( www.progress.com/.../rollbase ) with valid credentials. Progress pacific console page will be displayed. 2) Click on “Build Apps with Rollbase”. Progress Rollbase home page will be displayed. 3) Click on “New App”. 4) Choose “A new Application (from scratch) ” or User can choose desired option. Click on “Create”. 5) Enter any Application name (Ex: abc) then click on Save. 6) Click on + to create new object. 7) Select “A new Object (with Tab) From an External Metadata”. Click on Create. 8) Select “Data Direct Cloud” option then click on Next. 9) Enter Data Direct Cloud Credentials and enter above created connection name (Step 5 in before section) as Data Source field value. Click on Next. 10) Choose any table from “Select Table” drop down menu. 11) Enter values in other required fields. Click on “Create Object”. 12) Select any Primary key. Some system field’s type will be “None” by default. These fields will not be created in Rollbase. Change the type to “None” if you don’t want to create that field. Click on “Create Fields”. Thanks Srinivas
