agent_008_nl
Thanks Edsel, I have the example working (the afterfill commented out appeared to be the problem). Even though the Mobile App Builder with its design tool gives you high productivity, you can build mobile apps by just using HTML/JS and CSS and package them with PhoneGap/Cordova. You can use any web development or even a text editor. I know some people are experimenting with the jsdo in other web / mobile development tools. For example servoy. It could be an alternative for the javaproxy also. - progress.js and progress.session.js are now distributed as progress.jsdo. version .js via the Mobile App Builder. As Shelley Chase mentioned your license question from few weeks back, in the near future, this library would be available as Open Source on GitHub. In the meantime the .js is downloadable at oemobiledemo.progress.com/.../progress.jsdo.3.0.js of course (just for learning purposes). -- Kind regards, Stefan Houtzager Houtzager ICT consultancy & development www.linkedin.com/in/stefanhoutzager
