Forum Post: Re: Create Mobile App - First Step And Ask For Help
  • Thread starter Thread starter Sanjeev Reddy
Sanjeev Reddy
Hi Piotr, PDS OE is a separate OpenEgde component that user need to install specifically if he/she plans to develop OpenEdge applications using PDS OE. You can check whether PDS OE installed or not from “License Info” start menu item. To launch License Info start menu item, go to “Start Menu > All Programs > Progress > OpenEdge > License Info”. In this dialog you can find all the OpenEdge components installed in your machine, you can find an Product Name entry with “Progress Developer Studio OE” if PDS OE is installed. If PDS OE is installed, you can launch PDS OE from “Start Menu > All Programs > Progress > OpenEdge >Progress Developer Studio 3.7 - Clean” (for 11.2). Hope this helps, Sanjeev.
