Rob Fitzpatrick
So the BI/AI block size and BI cluster size are set to default, and buffers are set just above the defaults. When the concern is a bottleneck in transaction throughput those are the first things I'd change. Note this does require a DB restart. I'd suggest the following as a starting point; it may not be perfect for your workload but it's an educated guess and better than the defaults: - BI block size 16 KB - AI block size 16 KB - BI cluster size 8 MB - -bibufs 100 - -aibufs 100 Then monitor as George has suggested during periods of high transaction activity and see how your commit rate and other metrics change. Hope this helps.
