Rom Elwell
Donicello, Thank you again for referencing the document 'What are the basic steps to authenticate REST clients against the OpenEdge database _User table?". I have reviewed that document, in fact, and have a copy of it in front of me as I type this reply. It is because of that document that I opened this thread. In this document, the following block of text appears: Secure the HybridRealm class to prevent it from being called by any other AppServer client. You can do this by generating a Client-Principal file using the genspacp.bat utility by running the following in a Proenv window: genspacp -password RESTSPAPassword -role RESTSpaClient genspacp 1.0 Generated sealed Client Principal... User: BPSServer@OESPA Id: SmjnCQ1kTm2fY5r8pxQg5A Role: RESTSpaClient Encoded Password: oech1::02171c130115120331213c303d3737 File: oespaclient.cp State: SSO from external authentication system Seal is valid I was not sure if the User, Role and Domain referenced in the snippet above was cut/paste from another source in which the User, Role and Domain were already configured, or, as you alluded to in your reply, default values that will work without additional configuration needed.
