anikumar
Hi Carlos, There are couple of Build options which will enhance your performance (on startup or launch of an application) in PDS OE. Can you please un-check (or turn OFF) following options in PDS OE 1) 'Build Automatically' option in Project menu (Project - Build Automatically) 2) 'Compile on Save if required' in Preferences page Window - Preferences - Progress OpenEdge - Editor - Build. If you are modifying the PROPATH entries during your test, then please make sure that "Build only when source files are newer than r-code" option is turned ON in the project properties page Project Properties - Progress OpenEdge - Build Hope this helps. Thanks and Regards, Anil Kumar.
