RichardWalsh
Hello Santosh Actually we are not using the Class Object... I probably would not have undeployed it in Case it was some kine of Rollbase 'reserved object' but I will not try that. Thanks for the reply and info. Richard From: "Santosh Patel" bounce-sapatel@community.progress.com To: "TU Rollbase" TU.Rollbase@community.progress.com Sent: Wednesday, 11 June, 2014 2:48:24 PM Subject: RE: [Technical Users - Rollbase] Can "Class" be removed from Rollbase Calendar entry RE: Can "Class" be removed from Rollbase Calendar entry Reply by Santosh Patel Unfortunately the calendar component shows up all Object definitions (with either Task or Event attribute selected) that are in the deployed state for the Customer/Tenant. If you are not using the Class object elsewhere, you can undeploy it to remove from the above list but I guess you are obviously using it elsewhere. Regards, Santosh Stop receiving emails on this subject. Flag this post as spam/abuse.
