Forum Post: RE: Can "Class" be removed from Rollbase Calendar entry
  • Thread starter Thread starter Santosh Patel
Santosh Patel
Unfortunately the calendar component shows up all Object definitions (with either Task or Event attribute selected) that are in the deployed state for the Customer/Tenant. If you are not using the Class object elsewhere, you can undeploy it to remove from the above list but I guess you are obviously using it elsewhere. Regards, Santosh
