Forum Post: Re: Automation Toolkit : Ant Release Issues
  • Thread starter Thread starter asthomas
asthomas
Hey Carl, Sorry to see you are having so much trouble with this ;-) A few comments: 1. We usually always set the basedir as part of the ant script call from the scripts or from the jenkins projects calling it. So I expect that it has not been tested without. 2. The old style property files are not really supported any more. So we should really take out any references to it. We only want to be using JSON files moving forward. So we should really look at what it is that is not working and get this resolved. What errors were you getting with using the JSON properties files ? We will take a look at your edits and get them into the next update. Thanks for your valuable input!
