jimgelly
Hello, We are running the Rollbase 3.0.4 Private cloud installation Directly connected to Openedge database and using external objects created from the database. Another Rollbase question - our Openedge application uses the progress _seq - sequence values. In our application we would usually retrieve the next sequence value on a new record and update. What is the best way in Rollbase to utilise progress sequence values. Ideally we want to be able to query the current value and then also assign the next value on create. Is this functionality supported? we have tried to use rollbase triggers with no luck. Any documentation or suggestions are very appreciated. Regards Jim
