Forum Post: NOT-ACTIVe on data-relation uses for navigating ?
  • Thread starter Thread starter gdb390
gdb390
In the online course of Using prodatasets there is a part explained where you can set the NOT-ACTIVE attribute on a data-relation. Example : define dataset dsOrderOrderLineItem for ttOrder, ttOrderLine, ttItem data-relation drOrderOrderLine for ttOrder, ttOrderLine relation-fields (Ordernum, Ordernum) data-relation drOrderLineItem for ttOrderLine, ttItem relation-fields (Itemnum, Itemnum) data-relation drItemOrderLine for ttItem, ttOrderline relation-fields (Itemnum, Itemnum) NOT-ACTIVE. In the joining text, there is following comment : drOrderLineItem is used for FILL operation (OK, I get that) drItemOrderLine could be used for navigating the prodatasets. What is meant with the latter ? How this is used in an example ? Kind regards Gerd
