Forum Post: More xref issues
  • Thread starter Thread starter Thomas Mercer-Hursh
Thomas Mercer-Hursh
I expected from the documentation that there would be significantly more information in the XREF than previously, but I am beginning to be more impressed by what is not there. For example, given the following program: define variable hnFoo as handle no-undo. run foo.p persistent set hnFoo. run xyx in hnFoo. I would have expected the reference for run xyx to show me that it was being run *in* something else. I can see that foo.p is being run persistently, but nothing about the run reference for xyz tells me that it isn't simply a program. Reference Reference-type="RUN" Object-identifier="foo.p" Source-guid 7CZDg+a0fovhE6poZGFutQ /Source-guid File-num 1 /File-num Ref-seq 5 /Ref-seq Line-num 2 /Line-num Object-context PERSISTENT /Object-context Access-mode/ Data-member-ref/ Temp-ref/ Detail/ Is-static false /Is-static Is-abstract false /Is-abstract /Reference Reference Reference-type="RUN" Object-identifier="xyx" Source-guid 7CZDg+a0fovhE6poZGFutQ /Source-guid File-num 1 /File-num Ref-seq 6 /Ref-seq Line-num 3 /Line-num Object-context/ Access-mode/ Data-member-ref/ Temp-ref/ Detail/ Is-static false /Is-static Is-abstract false /Is-abstract /Reference
