Forum Post: How to refer to an extent field with LABEL Attribute of a buffer-field object
  • Thread starter Thread starter khaidirdedy
K
khaidirdedy
Hi everyone, I am new to Progress OpenEdge. I'm trying to get sortof like caption of the field from an array fields, in this case it was the LABEL or; COLUMN-LABEL from a field. here is my code: DEFINE VARIABLE i AS INTEGER NO-UNDO. DEFINE VARIABLE j AS INTEGER NO-UNDO. DEFINE VARIABLE hFld AS HANDLE NO-UNDO. DEFINE VARIABLE bfHandle AS HANDLE NO-UNDO. DEFINE VARIABLE qrHandle AS HANDLE NO-UNDO. CREATE BUFFER bfHandle FOR TABLE "tt-table". CREATE QUERY qrHandle. qrHandle:SET-BUFFERS( bfHandle ). qrHandle:QUERY-PREPARE( "FOR EACH tt-table" ). qrHandle:QUERY-OPEN(). qrHandle:GET-FIRST( NO-LOCK ). DO i = 1 TO ( bfHandle:NUM-FIELDS ): hFld = bfHandle:BUFFER-FIELD(i). /* handle the field */ IF ( hFld:EXTENT 0 ) THEN /* field is an array */ DO: DO j = 1 TO hFld:EXTENT: MESSAGE hFld:BUFFER-VALUE(j) VIEW-AS ALERT-BOX INFO. /* this is the field value of an array field */ -- MESSAGE hFld:COLUMN-LABEL(j) VIEW-AS ALERT-BOX INFO. /* this is what i am trying to get for */ END. END. END. Is it possible for me to get the LABEL or COLUMN-LABEL or NAME of an Array field? Any help and answer would be appreciated. Thank you.
