Forum Post: HELP Debugging OEREALM-FORM Authentication
  • Thread starter Thread starter Paul Koufalis
P
Paul Koufalis
This works on my laptop but not on my Linux box with a regular Tomcat environment. I may very well have forgotten a step: - Changed web.xml to user oerealm-form - Changed appsec-oerealm-form to point to my AppServer and the appropriate class name - Deployed the class files to my AppServer PROPATH directory - Changed log4j.properties for DEBUG logging - I am using static/auth/login.html - static/auth/j_spring_security_check is returning "Unauthorized" In adapters/logs/myapp.log I see: 2014-08-14 15:49:45,469 1540327 [http-nio-8080-exec-87] ERROR com.progress.rest.security.OERealmUserDetailsImpl loadUserByUsername - Username load error for root re: general error: org.springframework.security.core.userdetails.UsernameNotFoundException: User account not found 2014-08-14 15:49:45,469 1540327 [http-nio-8080-exec-87] ERROR com.progress.rest.security.OERealmUserDetailsImpl loadUserByUsername - Username load error for root re: general error: org.springframework.security.core.userdetails.UsernameNotFoundException: User account not found In my Apsv.server.log I see: [14/08/14@16:49:45.468-0400] P-016268 T-149772064 3 AS AS requestID= REQ|null|00000008 [14/08/14@16:49:45.468-0400] P-016268 T-149772064 4 AS AS -- TRACE: Open4GLWriteLast 72. (8401) [14/08/14@16:49:45.468-0400] P-016268 T-149772064 4 AS AS -- TRACE: Open4GLWrite 72. (8402) [14/08/14@16:49:45.468-0400] P-016268 T-149772064 4 AS AS -- TRACE: cso4GL: Before loadProc() (8458) [14/08/14@16:49:45.468-0400] P-016268 T-149772064 4 AS AS -- TRACE: STATELESS: locating proxy-id 69733a78 (sp2kRealm:ValidateUser) for operation 16 (8458) [14/08/14@16:49:45.468-0400] P-016268 T-149772064 3 AS AS -- TRACE: SINGLETON Non-Void Method 'sp2kRealm:ValidateUser' START (16820) [14/08/14@16:49:45.468-0400] P-016268 T-149772064 4 AS AS -- TRACE: STATELESS: located proxy-id 69733a78 (sp2kRealm:ValidateUser) for operation 16 (8458) [14/08/14@16:49:45.468-0400] P-016268 T-149772064 4 AS AS -- TRACE: cso4GL: After successful loadProc() (8458) [14/08/14@16:49:45.468-0400] P-016268 T-149772064 4 AS AS -- TRACE: Set open 4GL server state to 2. (8400) [14/08/14@16:49:45.468-0400] P-016268 T-149772064 4 AS AS -- TRACE: cso4GL: In execProc() - before execution. (8458) [14/08/14@16:49:45.468-0400] P-016268 T-149772064 4 AS AS -- TRACE: STATELESS: running stateless internal function on proxy-id 69733a78 (8458) [14/08/14@16:49:45.468-0400] P-016268 T-149772064 2 AS 4GLTRACE Invoke ValidateClient [ValidateUser - sp2kRealm @ 469] [14/08/14@16:49:45.468-0400] P-016268 T-149772064 3 AS 4GLTRACE Return from ValidateClient "yes" [sp2kRealm] [14/08/14@16:49:45.468-0400] P-016268 T-149772064 3 AS AS -- TRACE: SINGLETON Non-Void Method END SUCCESS (16821) [14/08/14@16:49:45.469-0400] P-016268 T-149772064 4 AS AS -- TRACE: cso4GL: In execProc() - successful execution. (8458) [14/08/14@16:49:45.469-0400] P-016268 T-149772064 4 AS AS -- TRACE: cso4GL: In execCall() - execProc() success. (8458) [14/08/14@16:49:45.469-0400] P-016268 T-149772064 4 AS AS -- TRACE: Set open 4GL server state to 3. (8400) [14/08/14@16:49:45.469-0400] P-016268 T-149772064 4 AS AS Server Message state = MSGSTATE_SENDRESP [14/08/14@16:49:45.469-0400] P-016268 T-149772064 4 AS AS -- TRACE: Set open 4GL server state to 1. (8400) [14/08/14@16:49:45.469-0400] P-016268 T-149772064 4 AS AS -- TRACE: open4GLRead 51. (8403) [14/08/14@16:49:45.469-0400] P-016268 T-149772064 4 AS AS Server Message state = MSGSTATE_FINISHRQ [14/08/14@16:49:45.469-0400] P-016268 T-149772064 4 AS AS Server Message state = MSGSTATE_IDLE On my laptop it continues doing a bunch more calls to the hybridrealm class. I hope it's something dumb.
