aaravindhantj
sir pls assume that a database is start up and running in multi user mode in a remote server with all defined start up parameters. In remote client we set a bat file with all sort of client connection parameters. both the database and client are using open edge only. my question is whether the remote client should start up the connected in single user mode or in multiuser mode to the database and if the the number of clients is around 50 then the each client will execute the connection bat file in his separate client terminal and if this the scenario will the all 50 client will successfully connect to the server database which is started and running in mutiuser mode. thank you sir very much
