Forum Post: Corticon WSDL and XMLBeans
  • Thread starter Thread starter yunakao
Y
yunakao
Anyone has any idea why I got this error when try to create WebService Client Using XMLBean ? command: -uri http://localhost:8082/axis/WSDL/SmartPhonePrice_contract.wsdl -sn SmartPhonePriceDecisionService -pn SmartPhonePriceDecisionServiceSoap -s -d xml beans --noBuildXML -o c:/work/out My Error Message: org.apache.axis2.wsdl.codegen.CodeGenerationException: java.lang.RuntimeException:java.lang.reflect.InvocationTargetException at org.apache.axis2.wsdl.codegen.CodeGenerationEngine.generate(CodeGenerationEngine.java:271) at org.apache.axis2.wsdl.WSDL2Code.main(WSDL2Code.java:35) at org.apache.axis2.wsdl.WSDL2Java.main(WSDL2Java.java:24) at jp.co.canon_soft.wp.runtime.webservice_impl.WSProxyCreator.main(WSProxyCreator.java:146) Caused by: java.lang.RuntimeException: java.lang.reflect.InvocationTargetException at org.apache.axis2.wsdl.codegen.extension.XMLBeansExtension.engage(XMLBeansExtension.java:126) Java Result: 1 at org.apache.axis2.wsdl.codegen.CodeGenerationEngine.generate(CodeGenerationEngine.java:224) ... 3 more Caused by: java.lang.reflect.InvocationTargetException at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at org.apache.axis2.wsdl.codegen.extension.XMLBeansExtension.engage(XMLBeansExtension.java:115) ... 4 more Caused by: java.lang.RuntimeException: org.apache.xmlbeans.XmlException: error: cvc-complex-type.3.2.2: Attribute not allowed: value in element attribute@http://www.w3.org/2001/XMLSchema at org.apache.axis2.xmlbeans.CodeGenerationUtility.processSchemas(CodeGenerationUtility.java:325) ... 9 more Caused by: org.apache.xmlbeans.XmlException: error: cvc-complex-type.3.2.2: Attribute not allowed:value in element attribute@http://www.w3.org/2001/XMLSchema at org.apache.xmlbeans.impl.schema.SchemaTypeSystemCompiler.compile(SchemaTypeSystemCompiler.java:225) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at org.apache.xmlbeans.XmlBeans.compileXmlBeans(XmlBeans.java:667) at org.apache.axis2.xmlbeans.CodeGenerationUtility.processSchemas(CodeGenerationUtility.java:189) ... 9 more MY Corticon WSDL ?xml version="1.0" encoding="UTF-8"? definitions xmlns="http://schemas.xmlsoap.org/wsdl/" xmlns:tns="http://localhost:8082/axis/services/Corticon/untitled_1" xmlns:cc="urn:decision:untitled_1" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:soap="http://schemas.xmlsoap.org/wsdl/soap/" targetNamespace="http://localhost:8082/axis/services/Corticon/untitled_1" types xsd:schema xmlns:tns="urn:decision:untitled_1" targetNamespace="urn:decision:untitled_1" elementFormDefault="qualified" xsd:element name="CorticonRequest" type="tns:CorticonRequest" / xsd:element name="CorticonResponse" type="tns:CorticonResponse" / xsd:complexType name="CorticonRequest" xsd:sequence xsd:element name="ExecutionProperties" type="tns:ExecutionPropertiesRequest" minOccurs="0" maxOccurs="1" / xsd:element name="WorkDocuments" type="tns:WorkDocumentsRequest" / /xsd:sequence xsd:attribute name="decisionServiceName" use="required" fixed="untitled_1" type="xsd:string" / /xsd:complexType xsd:complexType name="CorticonResponse" xsd:sequence xsd:element name="ExecutionProperties" type="tns:ExecutionPropertiesResponse" minOccurs="0" maxOccurs="1" / xsd:element name="WorkDocuments" type="tns:WorkDocumentsResponse" / xsd:element name="Messages" type="tns:Messages" / /xsd:sequence xsd:attribute name="decisionServiceName" use="required" fixed="untitled_1" type="xsd:string" / /xsd:complexType xsd:complexType name="ExecutionProperties" xsd:sequence xsd:element name="ExecutionProperty" type="tns:ExecutionProperty" minOccurs="0" maxOccurs="unbounded" / /xsd:sequence /xsd:complexType xsd:complexType name="ExecutionProperty" xsd:sequence / xsd:attribute name="executionPropertyName" use="required" type="xsd:string" / xsd:attribute name="executionPropertyValue" use="required" type="xsd:string" / /xsd:complexType xsd:complexType name="WorkDocumentsRequest" xsd:choice maxOccurs="unbounded" xsd:element name="contract_entity" type="tns:contract_entityRequest" / /xsd:choice xsd:attribute name="messageType" fixed="HIER" use="required" type="xsd:string" / /xsd:complexType xsd:complexType name="WorkDocumentsResponse" xsd:choice maxOccurs="unbounded" xsd:element name="contract_entity" type="tns:contract_entityResponse" / /xsd:choice xsd:attribute name="messageType" fixed="HIER" use="required" type="xsd:string" / /xsd:complexType xsd:complexType name="Messages" xsd:sequence xsd:element name="Message" type="tns:Message" minOccurs="0" maxOccurs="unbounded" / /xsd:sequence xsd:attribute name="version" type="xsd:string" / /xsd:complexType xsd:complexType name="Message" xsd:sequence xsd:element name="severity" xsd:simpleType xsd:restriction base="xsd:string" xsd:enumeration value="Info" / xsd:enumeration value="Warning" / xsd:enumeration value="Violation" / /xsd:restriction /xsd:simpleType /xsd:element xsd:element name="text" type="xsd:string" / xsd:element name="entityReference" xsd:complexType xsd:attribute name="href" type="xsd:anyURI" / /xsd:complexType /xsd:element /xsd:sequence /xsd:complexType xsd:complexType name="contract_entityRequest" xsd:sequence xsd:element name="contractid" type="xsd:long" nillable="true" minOccurs="0" / xsd:element name="contracttype" type="xsd:string" nillable="true" minOccurs="0" / xsd:element name="monthlyprice" type="xsd:long" nillable="true" minOccurs="0" / xsd:element name="priceplan" type="xsd:long" nillable="true" minOccurs="1" / xsd:element name="申込日" type="xsd:date" nillable="true" minOccurs="1" / xsd:element name="オプション" type="tns:option_entityRequest" minOccurs="0" maxOccurs="unbounded" / xsd:element name="サービス" type="tns:service_entityRequest" minOccurs="0" maxOccurs="unbounded" / xsd:element name="割引" type="tns:discount_entityRequest" minOccurs="0" maxOccurs="unbounded" / xsd:element name="契約機種別割引" type="tns:契約機種別割引Request" minOccurs="0" / xsd:element name="契約別割引" type="tns:契約別割引Request" minOccurs="0" / xsd:element name="携帯電話" type="tns:mobilephone_entityRequest" minOccurs="0" / /xsd:sequence /xsd:complexType xsd:complexType name="discount_entityRequest" xsd:sequence xsd:element name="discountname" type="xsd:string" nillable="true" minOccurs="0" / xsd:element name="discountprice" type="xsd:long" nillable="true" minOccurs="0" / xsd:element name="maxdiscountapplymonth" type="xsd:long" nillable="true" minOccurs="0" / /xsd:sequence /xsd:complexType xsd:complexType name="mobilephone_entityRequest" xsd:sequence xsd:element name="diskvolume" type="xsd:string" nillable="true" minOccurs="1" / xsd:element name="mobilephonename" type="xsd:string" nillable="true" minOccurs="1" / xsd:element name="price" type="xsd:long" nillable="true" minOccurs="0" / /xsd:sequence /xsd:complexType xsd:complexType name="option_entityRequest" xsd:sequence xsd:element name="maxoptionapplymonth" type="xsd:long" nillable="true" minOccurs="0" / xsd:element name="optionname" type="xsd:string" nillable="true" minOccurs="0" / xsd:element name="optionprice" type="xsd:long" nillable="true" minOccurs="0" / /xsd:sequence /xsd:complexType xsd:complexType name="service_entityRequest" xsd:sequence xsd:element name="maxserviceapplymonth" type="xsd:long" nillable="true" minOccurs="0" / xsd:element name="serviceprice" type="xsd:long" nillable="true" minOccurs="0" / xsd:element name="サービス名" type="xsd:string" nillable="true" minOccurs="0" / /xsd:sequence /xsd:complexType xsd:complexType name="契約別割引Request" xsd:sequence xsd:element name="契約別割引名" type="xsd:string" nillable="true" minOccurs="0" / xsd:element name="契約別割引料" type="xsd:long" nillable="true" minOccurs="0" / xsd:element name="契約別最大割引期間月" type="xsd:long" nillable="true" minOccurs="0" / /xsd:sequence /xsd:complexType xsd:complexType name="契約機種別割引Request" xsd:sequence xsd:element name="契約機種別割引適用期間月" type="xsd:long" nillable="true" minOccurs="0" / xsd:element name="契約機種別割引料" type="xsd:long" nillable="true" minOccurs="0" / /xsd:sequence /xsd:complexType xsd:complexType name="contract_entityResponse" xsd:sequence xsd:element name="contractid" type="xsd:long" nillable="true" minOccurs="0" / xsd:element name="contracttype" type="xsd:string" nillable="true" minOccurs="0" / xsd:element name="monthlyprice" type="xsd:long" nillable="true" minOccurs="0" / xsd:element name="priceplan" type="xsd:long" nillable="true" minOccurs="1" / xsd:element name="申込日" type="xsd:date" nillable="true" minOccurs="1" / xsd:element name="オプション" type="tns:option_entityResponse" minOccurs="0" maxOccurs="unbounded" / xsd:element name="サービス" type="tns:service_entityResponse" minOccurs="0" maxOccurs="unbounded" / xsd:element name="割引" type="tns:discount_entityResponse" minOccurs="0" maxOccurs="unbounded" / xsd:element name="契約機種別割引" type="tns:契約機種別割引Response" minOccurs="0" / xsd:element name="契約別割引" type="tns:契約別割引Response" minOccurs="0" / xsd:element name="携帯電話" type="tns:mobilephone_entityResponse" minOccurs="0" / /xsd:sequence xsd:attribute name="id" type="xsd:ID" use="optional" / /xsd:complexType xsd:complexType name="discount_entityResponse" xsd:sequence xsd:element name="discountname" type="xsd:string" nillable="true" minOccurs="0" / xsd:element name="discountprice" type="xsd:long" nillable="true" minOccurs="0" / xsd:element name="maxdiscountapplymonth" type="xsd:long" nillable="true" minOccurs="0" / /xsd:sequence xsd:attribute name="id" type="xsd:ID" use="optional" / /xsd:complexType xsd:complexType name="mobilephone_entityResponse" xsd:sequence xsd:element name="diskvolume" type="xsd:string" nillable="true" minOccurs="1" / xsd:element name="mobilephonename" type="xsd:string" nillable="true" minOccurs="1" / xsd:element name="price" type="xsd:long" nillable="true" minOccurs="0" / /xsd:sequence xsd:attribute name="id" type="xsd:ID" use="optional" / /xsd:complexType xsd:complexType name="option_entityResponse" xsd:sequence xsd:element name="maxoptionapplymonth" type="xsd:long" nillable="true" minOccurs="0" / xsd:element name="optionname" type="xsd:string" nillable="true" minOccurs="0" / xsd:element name="optionprice" type="xsd:long" nillable="true" minOccurs="0" / /xsd:sequence xsd:attribute name="id" type="xsd:ID" use="optional" / /xsd:complexType xsd:complexType name="service_entityResponse" xsd:sequence xsd:element name="maxserviceapplymonth" type="xsd:long" nillable="true" minOccurs="0" / xsd:element name="serviceprice" type="xsd:long" nillable="true" minOccurs="0" / xsd:element name="サービス名" type="xsd:string" nillable="true" minOccurs="0" / /xsd:sequence xsd:attribute name="id" type="xsd:ID" use="optional" / /xsd:complexType xsd:complexType name="契約別割引Response" xsd:sequence xsd:element name="契約別割引名" type="xsd:string" nillable="true" minOccurs="0" / xsd:element name="契約別割引料" type="xsd:long" nillable="true" minOccurs="0" / xsd:element name="契約別最大割引期間月" type="xsd:long" nillable="true" minOccurs="0" / /xsd:sequence xsd:attribute name="id" type="xsd:ID" use="optional" / /xsd:complexType xsd:complexType name="契約機種別割引Response" xsd:sequence xsd:element name="契約機種別割引適用期間月" type="xsd:long" nillable="true" minOccurs="0" / xsd:element name="契約機種別割引料" type="xsd:long" nillable="true" minOccurs="0" / /xsd:sequence xsd:attribute name="id" type="xsd:ID" use="optional" / /xsd:complexType /xsd:schema /types message name="CorticonRequestIn" part name="parameters" element="cc:CorticonRequest" / /message message name="CorticonResponseOut" part name="parameters" element="cc:CorticonResponse" / /message portType name="untitled_1Soap" operation name="processRequest" input message="tns:CorticonRequestIn" / output message="tns:CorticonResponseOut" / /operation /portType binding name="untitled_1Soap" type="tns:untitled_1Soap" soap:binding transport="http://schemas.xmlsoap.org/soap/http" style="document" / operation name="processRequest" soap:operation soapAction="urn:decision:untitled_1" style="document" / input soap:body use="literal" namespace="urn:decision:untitled_1" / /input output soap:body use="literal" namespace="urn:decision:untitled_1" / /output /operation /binding service name="untitled_1" documentation / port name="untitled_1Soap" binding="tns:untitled_1Soap" soap:address location="http://localhost:8082/axis/services/Corticon" / /port /service /definitions
