Forum Post: AW: Using toString() on Progress Dates
  • Thread starter Thread starter Mike Fechner
Mike Fechner
CAST does not create a new object instance. So there is no need to DELETE object the result of the CAST separate from the result of the BOX. They are the same reference. Von: James Palmer [mailto:bounce-jdpjamesp@community.progress.com] Gesendet: Donnerstag, 13. November 2014 09:43 An: TU.OE.Development@community.progress.com Betreff: RE: [Technical Users - OE Development] Using toString() on Progress Dates RE: Using toString() on Progress Dates Reply by James Palmer So here's a question. I can assign the result of the BOX to a variable and clear that up after I've used it. I can't find a way though to capture the result of the CAST so I can clear that up, and if I comment out the CAST bit (so just use a BOX) the memory increase is minimal anyway. Stop receiving emails on this subject. Flag this post as spam/abuse.
