Forum Post: ABLUnit with ANT batchtest
  • Thread starter Thread starter willer
W
willer
Hello, 1. the current batchtest option for ABLUnit starts for every found Test class a new AVM Session. This takes for one Testclass many times longer than the test itself. Is it possible to keep the session open until all tests are finished? 2. When the Structure of my project folder is like: Case1/Test.cls Case2/Test.cls ... Then the outputfile of the test from Case2/Test.cls overwrites the result from Case1/Test.cls since the batchtest contains only an todir option. Is it possible to define the filename pattern of the geneerated result? batchtest todir="${basedir}/results" format="xml" fileset dir="${basedir}/samples1" include name="**/Test*.cls" / /fileset /batchtest Thank you Peter Willer
