Hi all,
i am trying to understand what is wrong here. It simply stucks as it shall view the report. The ocx remains blank. and i get an error with CRViewer.dll. I checked the dll, it is registred correctly and i have admin right onto it.
here is my code .
If anyone could find where is my mistake,please tell
sorry if i put it in the wrong part , but as it refers to database.
here is my code .
/*SESSION:IMMEDIATE-DISPLAY = FALSE.*/
DEFINE VARIABLE crApplication AS COM-HANDLE NO-UNDO.
DEFINE VARIABLE crReport AS COM-HANDLE NO-UNDO.
CREATE "CrystalRuntime.Application" crApplication.
CREATE "CrystalRuntime.Report" crReport.
/* Set the report object */
crReport = crApplication:OpenReport("c:\temp\xml\Report1.rpt",1).
crReport:DATABASE:Tables:Item(1):SetTableLocation("c:\temp\xml\inte.xml","","").
crReport:DiscardSavedData().
/*crReport:VerifyOnEveryPrint = TRUE.*/
/* Enables the CRViewer's Navigation Controls */
chCtrlFrame:CrystalActiveXReportViewer:EnableNavigationControls = TRUE.
/* Enables the CRViewer's Export button */
chCtrlFrame:CrystalActiveXReportViewer:EnableExportButton = FALSE.
/* Disables the CRViewer's Search control */
chCtrlFrame:CrystalActiveXReportViewer:EnableSearchControl = FALSE.
/* Set the report source */
chCtrlFrame:CrystalActiveXReportViewer:ReportSource = crReport.
/* View the report */
chCtrlFrame:CrystalActiveXReportViewer:ViewReport().
RELEASE OBJECT crApplication.
RELEASE OBJECT crReport.
ASSIGN crApplication = ?
crReport = ?
/*SESSION:IMMEDIATE-DISPLAY = TRUE.*/
