Create an installation verification method/tool for schema
  • Thread starter Thread starter tcallen@dmsi.com
tcallen@dmsi.com
We have endured at least two Rollbase releases over the last six months where a schema update was not made or not completed correctly. As a result it caused many seemingly unrelated problems in Rollbase. Ideally, it would be a tremendous help if Progress could provide, with each major and minor release, a tool that crawls a private server/database install and verifies the schema is correct for that version of Rollbase that could be run after an install is finished. We've wasted considerable time tracking this latest issue and realized it was another schema mismatch causing problems down stream. Please seriously consider providing a verification/audit tool so that private installs are properly installed and contain correct schema definitions.
