Cim load program for 7.9.2
madhura
Hello All,
I would like to know is it possible to write cim load program to 7.9.2 menu . If so i would need training on how to write it as i have not written program so far in progress.
Hello
If you mean rcshwb.p which in my case in Pre-Shipper/Shipper Workbench then keystroke cimload in terminal mode could have some issues. I did a quick try of doing a shipper on unconfirmed order.
If in fact it could work there is plenty of cells to fill wich void or values.
As you can see on 32soft they have loader for that.
So a Cimload from excel could work.
Kind regards
Thank you for your reply . You mean to say creating the template in Excel and convert into cim and load it through Mfg/pro menu?
Yeah. If anything loading a file from the server through cimload menu would be the best option.Through this set of menus.
