Capture Smart Toolbar Mode
Mtas
I have a smartframe with SDO, Viewer and smart toolbar. On the toolbar apart from the normal add, delete, save button I have two other buttons which allow data entry. What i want to do is if the user changes something in the viewer thus resulting in the Save, cancel button being activated in the smart toolbar, disable the other two buttons which allow data entry.
What event would be best to use to capture data change. I dont want to do it on value-change of each fill-in or combo box I have. Any help will be appreciated.
Cheers.
