Calendar question, need help...
gocc
I'm running MFG/Pro on Progress 8.5E.
I'm trying to run 33.15.1 Operations Plan Maintenance (spfpmt.p) and the program is responding with message: ERROR: RUNCALENDAR CROSS-REFERENCE BUILD. Does anyone know what is it that I have to run?
Thanks!
May be a slightly different version but you should try 33.1.4
*33.1.1 GL Calendar Browse glbr003.p *
*33.1.2 GL Calendar Report glcalrp.p *
*33.1.4 Calendar Cross-Reference Build spglclmt.p *
*33.1.5 Calendar Cross-Reference Inquiry spglcliq.p *
