L
Lieven Cardoen
When writing for instance next Constructor, the OpenEdge eclipse plugin will search for the UltraToolbarsManager (when using Ctrl-Space) and your Ctor will look like: CONSTRUCTOR PUBLIC RibbonCustomizationDialog(ultraToolbarsManager AS Infragistics.Win.UltraWinToolbars.UltraToolbarsManager) ... After this, I always add a USING Infragistics.Win.UltraWinToolbars.UltraToolbarsManager FROM ASSEMBLY. too make the CONSTRUCTOR signature smaller. However, this is very annoying and like in most IDE's, it would be great to be able to choose whether I want to use the fully qualified name or let the plugin add a USING at the top and make the Ctor signature automatically: CONSTRUCTOR PUBLIC RibbonCustomizationDialog(ultraToolbarsManager AS UltraToolbarsManager) This is a great idea, but is Progress actually looking into these ideas? Or do I have to create a Support Case for this? There are other ideas as well for the Ecilpse Plugin like: - Fix usings -- removes unused usings, puts them in alphabetical order, ... - Refactoring... methods, variables, ... - Code completion/snippets for things like a DO WHILE, FOR statements, FIND statements, ... For instance, if in an IDE like Visual Studio or IntelliJ you whould type foreach with a TAB after it, you would get the whole structure. - Please provide a way to go over a collection like a FOREACH. I'm sure there's room for an extra keyword in Progress... As an example, In C#, iterating over a collection: foreach (var item in collection) { //Do something with the item } In ABL: DEFINE VARIABLE item AS Class NO-UNDO . DEFINE VARIABLE ItemEnumerator AS System.Collections.IEnumerator NO-UNDO . ASSIGN ItemEnumerator = CAST(THIS-OBJECT:Collection, System.Collections.IEnumerable):GetEnumerator() . ItemEnumerator:Reset() . DO WHILE ItemEnumerator:MoveNext() ON ERROR UNDO, THROW: ASSIGN item = CAST(ItemEnumerator:Current, Class) . END. Ow man, so ugly, compared to Java or C#... Maybe with a keyword FOREACH this could be improved... Ok, there are ways to do this shorter with an include file, but please, get rid of the include files for things like this.
