Question Using Browse
Greetings Everyone! I am using Progress 11.3 I have this problem using the browse widget because one of the field that I want to retrieve contains number, and this numbers represent a character value.
This is a simple program that is similar to what I am doing:
Database:
Table: UserInfo
lname = Character
Fname = Character
Sex = Integer (1 = Male,2 = Female)
DEFINE VAR t_row AS ROWID.
DEFINE VAR t_sex AS  INTEGER INIT 0.
DEFINE VAR t_vsex AS CHAR INIT "".
FOR EACH UserInfo.
  ASSIGN t_row = ROWID(forinsert.UserInfo).
  RUN xxx.
  DISPLAY Fname Lname t_vsex WITH 1 COL.
END.
PROCEDURE xxx:
  FIND UserInfo WHERE ROWID(UserInfo) EQ t_row.
  IF AVAIL (UserInfo) THEN DO:
  ASSIGN t_sex = UserInfo.Sex.
  IF t_sex EQ 1 THEN t_vsex = "Male".
  IF t_sex EQ 2 THEN t_vsex = "Female".
  END.
END PROCEDURE.
But I want to use a BROWSE WIDGET to display the output of this. I'm looking forward for your responses, thank you Everyone.
Fabio
Hello Arjon,
Try this:
FUNCTION GetGender RETURNS CHAR (iSex AS INT):
  DEF VAR ecGender AS CHAR EXTENT 2 INITIAL ['Male', 'Female'] NO-UNDO.
  RETURN ecGender[iSex].
END.
DEF QUERY qUsrInf FOR UserInfo.
DEF BROWSE bUsrInf QUERY qUsrInf DISPLAY Fname Lname GetGender(Sex) @ Sex
  WITH 17 DOWN TITLE "User Info".
OPEN QUERY qUsrInf FOR EACH UserInfo.
ENABLE bUsrInf.
WAIT-FOR WINDOW-CLOSE OF CURRENT-WINDOW.
Best regards,
Hello Arjon,
Try this:
END.
ENABLE bUsrInf.
Best regards,
Sir Fabio Thank you for response, it really help me :). Thank you very much.
