Version: 9.1C
OS: Win2000
I'm trying to change the font without using the
SYSTEM-DIALOG FONT command.
what I have to far is...
PUT-KEY-VALUE SECTION "Fonts" KEY fontnum VALUE fontstr
where (for example) fontnum = "font1" and
fontstr = "Arial, size=10"
When I do this and run a little program that shows all the fonts in the table, the font strings are correct. but the example fill-in at the bottom of the window shows the original font.
Also, my font changes aren't saved.
I've tried:
n = 10.
fontstr = "Arial, size=10".
fontnum = "font" + TRIM(STRING(n, ">>9")).
PUT-KEY-VALUE SECTION "Fonts" KEY fontnum VALUE fontstr.
PUT-KEY-VALUE FONT n.
this has no effect at all!
Please Help!
OS: Win2000
I've tried:
n = 10.
Please Help!
