Progress ODBC test hangs
oshkalabah
Hello,
We have some Progress ODBC connections on a server (Windows 2000 - ugh!). The company was purchased and now the Progress server is a member of a different Windows domain. It seems that now our Progress ODBC DSNs won't work. When I open one of them and try to test it just hangs.
They are using the Merant 3.70 32-bit Progress ODBC driver. Any assistance you can provide is appreciated!
Osh
medu
you've might have got some firewall in between as a bonus, if that's true see if you can get them to open the ports: the database broker as well as min/max listening port range.
medu
No firewall, I already verified that. What ports does Progress listen on that I could try to telnet to?
that depends on what the dba has set for the database broker, each database has it's own server that listen on different port unlike mysql or mssql where there is an 'instance' port for multiple databases
can you reach the new server by plain ping?
oshkalabah
Yes I can. Interestingly enough when I try to test the same ODBC connection on the Progress server (instead of the app server) it too hangs.
oshkalabah
Update - if I give the test long enough to time out I get the following error:
[MERANT][ODBC PROGRESS driver][PROGRESS]BROKER: Could not spawn a server. (1890).
Help! (and thank you!)
oshkalabah
Another - when I click OK to the above error I get:
[MERANT][ODBC PROGRESS driver][PROGRESS]Error establishing Open Interface Driver connection. (2575)
oshkalabah
And another! When I click OK to that error I get:
[MERANT][ODBC PROGRESS driver]Invalid attribute in connection string: Description.
(The description in the DSN is blank, appears to always has been)
medu
ok then, check the database server log and see why is that... see if there is a limit on number of servers and/or clients per server, the database log filse should give you the answers.
Casper
ProgressTalk.com Moderator
Staff member
What driver are you using. Is it by chance a merant 3.60 SQL89 driver?
Regards,
Casper.
