[progress Communities] [progress Openedge Abl] Forum Post: Re: Webspeed Pasoe - How Do I...
Mike Fechner
Also, using the command line to use "bin\tcman start" from the instance directory start seems to be the fastest way to start PASOE. That will also launch a Java Console Window. X'ing that is the fastest way to stop PASOE. When the instance was created from OEM, you will most likely have to run the DOS box "As Administrator".
